Print at Sep 28, 2026, 3:54:45 AM
Posted by ndhduong at Jun 20, 2012, 9:42:06 AM
Re: How to import furniture in Applet
I use source v3.5 downloaded from here (3.5 src )
I tried to run the code locally as an applet within Eclipse, and v3.5 source is a little different from what is explained in this post:
1.There is no zip files for catalog or texture. All the models and textures are individual files in io/resources folder. The .properties files are located in io folder
2.Parameters has to be set in Run Configurations option of Eclipse
So I followed the instructions and did the following:
1.Change path for models and textures in .properties files, as
icon#1=./resources/bed140x190.png
model#1=./resources/bed140x190.obj
2.Set parameters as followed:
Value:"./io/"
Value:"./io/"
However, the applet run without any models on the top left section.
I have intentionally changed the path for models to a wrong one then Eclipse produced error of "Unknown resource", which means the paths I used above should be processed properly.
About the parameters, I have tried both relative and absolute path (C:/...) but none worked.
Please give me some inputs.
Thank you
