Print at Sep 29, 2026, 3:26:53 AM
Posted by Mitsaki at Jul 10, 2012, 7:41:42 PM
angry   Problem in running SH3D in windows
Hello,
first of all, I wanted to say, that I have used SH3D in MACOS and I know all the steps to make it run.
I want to run it in Windows XP, 32-bit. I want to run SH3D 3.3, so I use -Djava.ext.dirs=lib;lib/windows/i386 (or no? I am not sure - nevertheless I also tried it with -Djava.ext.dirs=lib;lib/windows/x64), but I have the following error
???? 10, 2012 9:21:00 ?? javax.media.j3d.NativePipeline getSupportedOglVendor
SEVERE: java.lang.UnsatisfiedLinkError: no j3dcore-ogl-chk in java.library.path
Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231)
at java.security.AccessController.doPrivileged(Native Method)
at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200)
at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:65)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:77)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:416)
at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:315)
at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:224)
vException in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class javax.media.j3d.VirtualUniverse
at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(HomeComponent3D.java:239)
at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(HomeComponent3D.java:224)
at com.eteks.sweethome3d.swing.SwingViewFactory.createView3D(SwingViewFactory.java:99)
at com.eteks.sweethome3d.viewcontroller.HomeController3D.getView(HomeController3D.java:95)
at com.eteks.sweethome3d.swing.HomePane.createAttachDetach3DViewAction(HomePane.java:1625)
at com.eteks.sweethome3d.swing.HomePane.createAttachDetach3DViewMenuItem(HomePane.java:1601)
at com.eteks.sweethome3d.swing.HomePane.createMenuBar(HomePane.java:952)
at com.eteks.sweethome3d.swing.HomePane.<init>(HomePane.java:273)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(SwingViewFactory.java:107)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(HomeController.java:299)
at com.eteks.sweethome3d.HomeFramePane.<init>(HomeFramePane.java:88)
at com.eteks.sweethome3d.HomeFrameController.getView(HomeFrameController.java:62)
at com.eteks.sweethome3d.HomeFrameController.displayView(HomeFrameController.java:83)
at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(SweetHome3D.java:283)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(CollectionChangeSupport.ja
va:77)
va:60)
at com.eteks.sweethome3d.model.HomeApplication.addHome(HomeApplication.java:76)
at com.eteks.sweethome3d.SweetHome3D.run(SweetHome3D.java:562)
at com.eteks.sweethome3d.SweetHome3D$1$1.run(SweetHome3D.java:255)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.eteks.sweethome3d.SweetHome3D.run(SweetHome3D.java:569)
The thing is that I wasn't sure if I could do that on 32bit, so I also tried version 2.5 where I got the same error. I installed Java JDK 5. I am quite confused about what I have to do...Is there any chance that you know what I am doing wrong?
Thanks in advance
Mitsaki
