Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can not render or export to obj file » » » » Post: Can not render or export to obj file |
Print at Oct 6, 2026, 12:45:55 AM |
| Posted by miguel78 at Aug 5, 2012, 8:43:06 PM |
Can not render or export to obj file hi, i'm new to SH3d. Can not render one of my project. No problems with other files. Can not export to obj file to render with blender. java console shows following error Can't load texture: CLOTH_02.JPG Make sure it is located in the same server an d directory with the model file. the loader's base path is: jar:file:C:\Users\mi gui\Application Data\eTeks\Sweet Home 3D\work\3500-dda97bcc-c9e6-4442-8023-21e2b e1f305e\open8802407051458218221.sweethome3d!/185/ Exception in thread "AWT-EventQueue-0 " java.lang.ArrayIndexOutOfBoundsException: -1 at java.util.ArrayList.get(Unknown Source) at com.eteks.sweethome3d.model.Home.clone(Unknown Source) at com.eteks.sweethome3d.swing.PhotoPanel.startPhotoCreation(Unknown Sou rce) at com.eteks.sweethome3d.swing.PhotoPanel.access$000(Unknown Source) at com.eteks.sweethome3d.swing.PhotoPanel$1.actionPerformed(Unknown Sour ce) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Sour ce) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) Exception in thread "autoSaveTimer" java.lang.RuntimeException: java.lang.reflec t.InvocationTargetException at com.eteks.sweethome3d.io.AutoRecoveryManager.cloneAndSaveHomes(Unknow n Source) at com.eteks.sweethome3d.io.AutoRecoveryManager.access$500(Unknown Sourc e) at com.eteks.sweethome3d.io.AutoRecoveryManager$8.run(Unknown Source) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) Caused by: java.lang.reflect.InvocationTargetException at java.awt.EventQueue.invokeAndWait(Unknown Source) ... 5 more Caused by: java.lang.ArrayIndexOutOfBoundsException: -1 at java.util.ArrayList.get(Unknown Source) at com.eteks.sweethome3d.model.Home.clone(Unknown Source) at com.eteks.sweethome3d.io.AutoRecoveryManager$9.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) |
Current timezone is GMT Oct 6, 2026, 12:45:55 AM |
