Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Saving Sweet Home 3D files as DWG files » » » » Post: Re: Saving Sweet Home 3D files as DWG files |
Print at Oct 2, 2026, 11:25:50 PM |
| Posted by nicksoper at Aug 14, 2012, 4:59:00 PM |
Re: Saving Sweet Home 3D files as DWG files Hi All, I too have had the same issue, and this thread pops up in the search results for the problem. I found a fairly simple work around. If you export the files to .SVG, then convert to a .PDF (Adobe Illustrator can do it), there is an online tool that converts the .PDF to a .DWG file. This is the link to the online tool http://www.convertpdftoautocad.com/ Just so you know, I don't work for or own the website, the upload failed in Safari (I had to use Firefox) and I also don't know how good a job it does. I sent the file to an architect to check. If it's rubbish I will reply, but if I don't then give the method a go. ============================================ @hansmex on a separate note, I could not get the latest version of Blender to export to OBJ, and it seems the link to the plugin to extend the functionality to export to DWG on the Blender site is broken :( |
Current timezone is GMT Oct 2, 2026, 11:25:50 PM |
