Print at Oct 15, 2026, 2:56:04 AM
Posted by macfrog at Sep 9, 2012, 8:29:44 PM
Re: Niches in a round wall?
Thank you, very good! Handsomely!!!
the rectangle is written «NicheCurvedBack», where did you get it?
Svetlana,
Please donot use this tip, it is too complicated.
use the first one:
- make a curved wall
- place 3 "invisible box" to position (height from floor etc) and size you need
- check in 3D-view everything looks good
- apply your textures for the wall (last chance)
- select this wall AND the "inv. Box"es
- use "copy as new furniture" menu (-> plugin!) to MAKE the new wall
- open a new project, "Edit/Paste" the new Wall into it
- check (again) in 3D-view everything looks good
- Export 3D-View as obj (Menu) to
create your (final) Wall!
-Import that wall into your project! Done smile
Please note:
Changing color of the Wall isn't a problem; changing texture certainly is!
macfrog
