Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to stop ceiling floating above walls » » » » Post: Re: How to stop ceiling floating above walls |
Print at Sep 3, 2026, 4:39:25 AM |
| Posted by hansmex at Sep 23, 2012, 11:43:06 PM |
Re: How to stop ceiling floating above walls John, If you have drawn four walls, and then add a room, the ceiling will rest correctly on the four walls, provided they are of equal height. If not all your walls have the same height, you may get unpredictable results. If you need different wall heights, but still want a ceiling, you may use the Level function, and insert a ceiling/floor on the higher level. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 3, 2026, 4:39:25 AM |
