Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to stop ceiling floating above walls » » » » Post: Re: How to stop ceiling floating above walls |
Print at Sep 3, 2026, 6:35:15 AM |
| Posted by John37 at Sep 26, 2012, 3:47:11 PM |
Re: How to stop ceiling floating above walls Thanks, Hans. Funnily enough, it doesn't work if the (four) walls (all equal height) are lower than the height of the level in which they are drawn. In other words, it is not possible to have two or more different ceiling heights at one level. Because I have 4 different ceiling heights on the ground floor alone of our meditation centre, which I am designing with this wonderful program, and because I have several flat roofs at different heights on the ground floor, I've realized that I need to define many different Levels, which is what you mentioned in your reply. The extra Levels are simply to create ceilings or floors, and in some cases I seem to need one Level to create a ceiling and another Level to to create the flat roof above it. It's a bit messy but seems to work ok. Does that sound like the best way to do it or is there a simpler way, please? John |
Current timezone is GMT Sep 3, 2026, 6:35:15 AM |
