Print at Oct 6, 2026, 6:11:51 AM
Posted by macfrog at Oct 7, 2012, 6:51:04 PM
Re: Ramp between two levels - Wheelchair and loading dock ramp
Hello,
the easy way is to use a sloping wall, adapted to your size requirements. you place that wall onto the lower level of your design, reaching the upper one with its higher end.
i've done this in this example:
note the big dark ramps in the sublevel of the building, next to the garage. These are the "walls".
Very easy to adapt to your needs i believe.
macfrog
