Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: simplest way to make a roof » » » » Post: Re: simplest way to make a roof |
Print at Sep 3, 2026, 1:47:30 AM |
| Posted by macfrog at Oct 7, 2012, 7:42:59 PM |
Re: simplest way to make a roof hi, if you already read the tutorial, maybe these pictures will help you to imagine what to do: first, create some walls that will became your roofpanels. since we don't have a side view in sh3d, you'll have to take the dimensions for the roof from the dimensions of the (sloping) walls, which is illustrated here: the result, with textures etc., comes out as: ![]() after creating the panels simply follow the export/reimport procedure as described. the more complicated your roof is, the more work you got on your neck, i'm afraid. for simple roofs however, this is a quite easy way to do it. Good luck! macfrog |
Current timezone is GMT Sep 3, 2026, 1:47:30 AM |
