Print at Sep 29, 2026, 4:16:18 AM
Posted by Puybaret at Oct 21, 2012, 4:37:44 PM
Re: Problem creating photos
Thanks for your files. Fortunately, you had the good idea to send the SweetHome3D.l4j.ini.txt you use and the problem is with this file: you should rename it as SweetHome3D.l4j.ini without the final ".txt"extension.
