Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: copy the library with the textures that I created on my pc to another computer » » » » Post: Re: copy the library with the textures that I created on my pc to another computer |
Print at Sep 2, 2026, 8:45:50 PM |
| Posted by Puybaret at Oct 22, 2012, 8:09:16 AM |
Re: copy the library with the textures that I created on my pc to another computer The content of the eTeks/Sweet Home 3D is portable from a computer to another one and across different operating systems. The difference from a system to another is the name of this folder and where it should be found: - under Windows Vista / 7 / 8 / 10, this folder is C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D, - under Windows XP and previous versions of Windows, this folder is C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D, - under Mac OS X with the free version, it's the subfolder Library/Application Support/eTeks/Sweet Home 3D of your user folder, - under Mac OS X with the Mac App Store version, it's the subfolder Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D of your user folder, - under Linux and other Unix, it's the subfolder .eteks/sweethome3d of your user folder, - under the portable version, it's the subfolder data of the folder that contains Sweet Home 3D applications. Under Mac OS X, to ensure you pick the right eTeks folder, you can open a new window in the Finder, select Go > Go To Folder menu item (cmd + Shift + G shortcut), and enter the folder ~/Library/Application Support or ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D (with the ~ tilde sign prefix) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 2, 2026, 8:45:50 PM |
