Print at Sep 29, 2026, 10:05:43 AM
Posted by Puybaret at Oct 25, 2012, 9:26:45 AM
Re: How can I select all walls (to change thickness)
The simplest way is to click in the plan to bring focus into it, choose the Edit > Select all menu item, then select Plan > Modify walls. Nevertheless, if you already place doors and windows on walls, you will have to move them a little forward and backward so they adapt their depth to the new wall thickness.
