Print at Sep 26, 2026, 10:21:22 AM
Posted by Gaytan at Oct 29, 2012, 11:48:26 AM
Re: Update to 3.7; personal categories texture gone......
Emmanuel,
Moving of the project I did; you're right.
But I got the impression I 'lost texture items' right after installing 3.7....
Tip / hint maybe; is it possible to let a project e.g. 'MyHouse3D' refer to its own .xml instead of having all projects referring to preferences.xml?
Like that you know exactly which .xml you do need to move or not...
Also maybe put .xml in the folder with the project instead of 'ApplicationSupport/eTeks/etc'...
This I say because it would make it easier to move the project you're working on, on USB stick and take it with you.
Now you have to copy not only your project(s) folder but also the one under 'ApplicationSupport/eTeks/etc', having to overwrite each time the one on e.g. your laptop....
It would be nice if one only has to move / copy one folder in order to have all necessary files with you!?
Kind regards,
Ed
