Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installation woes on MacBook Pro » » » » Post: Re: Installation woes on MacBook Pro |
Print at Oct 2, 2026, 10:46:40 PM |
| Posted by Puybaret at Nov 21, 2012, 3:43:42 PM |
Re: Installation woes on MacBook Pro I think the problem comes from the fact that you made some tests with Java 7 while its development, and you never removed the JDK you installed. Do you have some subfolders in /System/Library/Java/JavaVirtualMachines/ or ~/Library/Java/JavaVirtualMachines/ folders (if you hate Terminal, you can type these directories with Finder > Go > Go To Folder menu item)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 10:46:40 PM |
