Print at Oct 2, 2026, 11:25:08 PM
Posted by Puybaret at Dec 27, 2012, 10:46:54 AM
Re: Select items in the room
Here are two tips you should use to help you select items:
- lock the base plan with the item in the Plan menu or the lock displayed at the top left corner of the plan to make rooms and walls unselectable,
- use contextual menu Select object to select one of the object where you right clicked with the mouse.
