Print at Sep 2, 2026, 5:20:27 PM
Posted by Puybaret at Jan 4, 2013, 10:20:57 AM
Re: Main window remains unrealizable when 3D view is detached
This must be bound to the window resizing interdiction I programmed in version 3.7 while a SH3D file is opened under Mac OS X. It was to avoid program freezing that may happened if the user tries to enlarge the window at that moment, but it seems to need some refinement.
As I could reproduce the bug you reported on my computer, I should be able to fix it in the next version. Meanwhile the workaround is easy, simply attach and detach again the 3D view.
