Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Questions about the jar executable version. » » » » Post: Re: Questions about the jar executable version. |
Print at Oct 13, 2026, 6:09:49 PM |
| Posted by Puybaret at Jan 14, 2013, 8:02:35 AM |
Re: Questions about the jar executable version. Under Windows, the Jar executable will run in 64 bit mode when launched with a 64 bit JRE. If you want to be absolutely sure about the chosen JRE, add its full path in front of the java command, or ensure you have no other JRE installed in your system. You can use plug-ins also with the Jar executable version too, but you can't double-click on SH3P files to easily install them under Windows and Mac OS X with that version. I should improve this in a coming version with new options in preferences. Meanwhile you can install plugins manually by copying SH3P files at the right place (see the section Adding plugins in the user's guide). any 64-bit version does not have to be a portable version of the program Sorry, I don't understand what you mean. Do you mean that I was wrong to propose both 32 bit and 64 bit executables in the portable version?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 13, 2026, 6:09:49 PM |
