Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released » » » » Post: Re: Furniture Library Editor Beta released |
Print at Sep 23, 2026, 12:35:44 PM |
| Posted by damcar at Jan 19, 2013, 4:02:24 PM |
Re: Furniture Library Editor Beta released Hi Puybaret,Hans and others I'm new to Sweet Home 3D and realy like it, but for the moment, I’m not getting very far! I have downloaded and installed the latest version of Sweet Home 3D (Version 3.7 Java Web Start). I have the latest Java version installed (1.7.0_09). And it works OK. I downloaded FurnitureLibraryEditor-1.9.jar and when I double-click on it My Nokia Suite opens! So I next tried to open the file with the same java file that Sweet Home 3D uses (javaws.exe) but I get a window “Application Error. Unable to launch the application” with two buttons [OK] & [Details] When I click on “details”: Under “launch file” it says “PK”. Under “Exception”, it says: JNLParseException[ Could not parse launch file. Error at line 0.] at com.sun.javaws.jnl.XMLFormat.parse(Unknown Source) at com.sun.javaws.jnl.XMLFormat.parse(Unknown Source) at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source) at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source) at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source) at com.sun.javaws.Main.launchApp(Unknown Source) at com.sun.javaws.Main.continueInSecureThread(Unknown Source) at com.sun.javaws.Main.access$000(Unknown Source) at com.sun.javaws.Main$1.run(Unknown Source) at java.lang.Thread.run(Unknown Source) and under “Wrapped Exception” it says: Failed to find the '<' charater that marks the end of a CDATA element. Exception parsing xml at line 0 at com.sun.deploy.xml.XMLParser.skipPCData(Unknown Source) at com.sun.deploy.xml.XMLParser.nextToken(Unknown Source) at com.sun.deploy.xml.XMLParser.parse(Unknown Source) at com.sun.javaws.jnl.XMLFormat.parse(Unknown Source) at com.sun.javaws.jnl.XMLFormat.parse(Unknown Source) at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source) at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source) at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source) at com.sun.javaws.Main.launchApp(Unknown Source) at com.sun.javaws.Main.continueInSecureThread(Unknown Source) at com.sun.javaws.Main.access$000(Unknown Source) at com.sun.javaws.Main$1.run(Unknown Source) at java.lang.Thread.run(Unknown Source) also tried to open it with javaw.exe – nothing happens! Also tried to open it with javacpl.exe – and I get the Java Control Panel opening! Also tried to open it with java.exe – and I get what looks like a DOS window open for about half a second, then nothing. Also tried to open it with jabswitch.exe – and nothing happens! There are other “exe” files in the same folder (C:\Program Files (x86)\Java\jre7\bin) but none of them have the “java” logo. I then tried, on the “run” command (Win 7Pro 64 bit): java -jar FurnitureLibraryEditor-1.9.jar and got the DOS window open for about half a second, then nothing. I have read each entry on each of the three pages in the forum, but can’t see any other suggestions referring to my problem. Does anybody have any ideas? Best regards, DamCar |
Current timezone is GMT Sep 23, 2026, 12:35:44 PM |
