Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released » » » » Post: Re: Furniture Library Editor Beta released |
Print at Sep 23, 2026, 1:10:53 PM |
| Posted by damcar at Jan 21, 2013, 9:15:10 AM |
Re: Furniture Library Editor Beta released Thanks for the reply, Puybaret. Got it - but not the first time! I thought it might help others if I explain what I had to do… So as you suggested, I pasted in the run command “java -jar D:\Downloads\architecture_sweet home\FurnitureLibraryEditor-1.9.jar” (without the “” and got what looked like a DOS window for about half a second, then nothing. I tried launching SH3D and then running the command prompt again. Still no better. I then copied the file FurnitureLibraryEditor-1.9.jar onto the C drive and ran the command “java -jar C:\FurnitureLibraryEditor-1.9.jar” and it worked! So either the file needs to be on the same drive as java **OR** my path was too long for the thing to work. Thanks again for your help. Best regards DamCar. |
Current timezone is GMT Sep 23, 2026, 1:10:53 PM |
