Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Saving Sweet Home 3D files as DWG files » » » » Post: Re: Saving Sweet Home 3D files as DWG files |
Print at Oct 3, 2026, 3:21:45 PM |
| Posted by Trav at Feb 4, 2013, 7:28:22 AM |
Re: Saving Sweet Home 3D files as DWG files Thank you for your response Puybaret. Based on the various responses I have received to my origianl question, do you think I will achieve my goal if I do the following? 1. Convert my .sh3d file to a .SVG file using the converter built into Sweet Home 3D. 2. Convert the .SVG file to a .PDF file using PDF Creator. 3. Then convert the .PDF file to a .DWG file using the tool http://www.convertpdftoautocad.com/ as suggested by nicksoper on 14 August. |
Current timezone is GMT Oct 3, 2026, 3:21:45 PM |
