Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Strange Artifacts in 3D » » » » Post: Re: Strange Artifacts in 3D |
Print at Sep 28, 2026, 10:18:48 AM |
| Posted by Puybaret at Feb 12, 2013, 2:01:48 AM |
Re: Strange Artifacts in 3D These are wrongly computed ceiling parts. As explained in the help, the elevation of each ceiling point of a room is equal to the height of the nearest end point of a wall. This works well enough for slopping walls but it may lead to strange results when you use a small wall in the middle of a room like you did. Move the points of the room away from the small wall and you'll get a correct flat ceiling (when you look at it from below). If you're interested only by an aerial point of view, you can also make the ceiling of the room invisible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 10:18:48 AM |
