Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem when multiple transparency objects » » » » Post: Re: Problem when multiple transparency objects |
Print at Sep 29, 2026, 1:32:35 AM |
| Posted by lmerckx at Feb 15, 2013, 3:32:08 PM |
Re: Problem when multiple transparency objects Thank you for your answer, Emmanuel. You are right : The problem was due to the mixing of the alpha parameter in MTL file (d) and the texture PNG file which had transparency. Removing transparency in PNG solves the problem. Thank you again, Laurent. |
Current timezone is GMT Sep 29, 2026, 1:32:35 AM |
