Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: "gray block" problem when dropping in furnature ..... » » » » Post: Re: "gray block" problem when dropping in furnature ..... |
Print at Sep 29, 2026, 8:55:50 PM |
| Posted by xtal_01 at Feb 15, 2013, 10:03:23 PM |
Re: "gray block" problem when dropping in furnature ..... I should add the gray block is only at one end. If I copy and paste a this item then rotate it 180, the block is at the other end. It is only visible from "one side". In other words, if I have the same item, side by side and rotate one 180 degrees, I can see a gray block at the end of one roof section when looking at the house from the front and then when rotated so that I am looking at the back, I see the other roof section with a gray block on it. thanks .... Mike |
Current timezone is GMT Sep 29, 2026, 8:55:50 PM |
