Print at Sep 27, 2026, 6:17:05 AM
Posted by hansmex at Feb 28, 2013, 3:40:53 PM
Re: Light doubt
Guilherme,
There still are a few issues with light.
1 - Light cannot be exported or imported.
If you have a lamp without light, you cannot add a light to it, then export and import it, in the hope that you then have a lamp with light. The light doesn't survive this process.
2 - Mirrors do not reflect light
If you look at an object in a mirror, you will be able to see that object.
If that object is in the dark, you will (obviously) not be able to see that object. You cannot use a mirror to throw light on your object, because the mirror doesn't reflect the light.
