Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls » » » » Post: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls |
Print at Sep 27, 2026, 8:12:52 PM |
| Posted by chicosRV at Mar 13, 2013, 8:32:20 PM |
I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the wallsI exported the scene made in the Sweet Home 3d in separate .obj (each element is a diferent .obj) and using a xml file i construct the scene for open it in other application (the xml file has the format that use the other application, it contains the position of each object , scale, etc) but i have a problem obtaining the position of the walls, it never shows in the same position the were in Sweet Home. I tried saving all the walls together and each one like a diferent obj but it doesn't work. The room(all the walls together) never is positioned in the same position; and saving each wall as diferent obj file, its encapsuled in a bounding box that is bigger(a bigger rectangle) and i can't obtain the position of the center of this bounding box |
Current timezone is GMT Sep 27, 2026, 8:12:52 PM |
