Print at Sep 26, 2026, 5:40:21 PM
Posted by Lynn22 at Mar 14, 2013, 5:19:25 PM
Re: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls
The pivot point of an obj room is fixed in the 2D plan at point 0-0 (top left of the view port)
If you start drawing at location 0-0 and expand to the right and down, the pivot point is at the center of the bottom corner of the back wall.
If you need your house to have its pivot point in the center then you should move all your walls to have the location 0-0 at the center of your house.
Hope this helps
