Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Wall two tone » » » » Post: Re: Wall two tone |
Print at Oct 14, 2026, 4:31:38 PM |
| Posted by Puybaret at Mar 14, 2013, 5:44:04 PM |
Re: Wall two tone I guess it's because the room you created is at a upper or lower level, and the start point from which the texture is drawn is always at a 0 elevation, repeating itself from this point (even if the wall starts at a higher elevation). I could change this behavior by starting to draw the texture at the bottom of each wall. It would make life easier for you and others with the same problem, but it would be less handy for people who want to draw walls with the same texture at intermediate levels, and even create incompatibilities with what they obtained in previous versions. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 14, 2026, 4:31:38 PM |
