Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Sunflow exception when running 64-bit JRE7 » » » » Post: Sunflow exception when running 64-bit JRE7 |
Print at Sep 27, 2026, 4:05:50 AM |
| Posted by robal at Mar 16, 2013, 2:59:34 PM |
Sunflow exception when running 64-bit JRE7 Hi, I've noticed that all Sunflow threads fail when trying to render on 64-bit JRE7. SH3D doesn't show any errors (the render process is simply stalled). You need to look at java console to see it. Exception: Exception in thread "Thread-24" java.lang.OutOfMemoryError: Java heap space at java.awt.image.DataBufferInt.<init>(Unknown Source) at java.awt.image.Raster.createPackedRaster(Unknown Source) at java.awt.image.DirectColorModel.createCompatibleWritableRaster(Unknown Source) at java.awt.image.BufferedImage.<init>(Unknown Source) at org.sunflow.image.readers.JPGBitmapReader.load(Unknown Source) at org.sunflow.core.Texture.load(Unknown Source) at org.sunflow.core.Texture.getBitmap(Unknown Source) at org.sunflow.core.Texture.getPixel(Unknown Source) at org.sunflow.core.shader.TexturedShinyDiffuseShader.getDiffuse(Unknown Source) at org.sunflow.core.shader.ShinyDiffuseShader.getRadiance(Unknown Source) at org.sunflow.core.shader.TexturedShinyDiffuseShader.getRadiance(Unknown Source) at org.sunflow.core.LightServer.shadeHit(Unknown Source) at org.sunflow.core.LightServer.traceReflection(Unknown Source) at org.sunflow.core.ShadingState.traceReflection(Unknown Source) at org.sunflow.core.shader.ShinyDiffuseShader.getRadiance(Unknown Source) at org.sunflow.core.LightServer.shadeHit(Unknown Source) at org.sunflow.core.LightServer.traceReflection(Unknown Source) at org.sunflow.core.ShadingState.traceReflection(Unknown Source) at org.sunflow.core.shader.MirrorShader.getRadiance(Unknown Source) at org.sunflow.core.LightServer.shadeHit(Unknown Source) at org.sunflow.core.LightServer.traceRefraction(Unknown Source) at org.sunflow.core.ShadingState.traceRefraction(Unknown Source) at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) at org.sunflow.core.LightServer.shadeHit(Unknown Source) at org.sunflow.core.LightServer.traceRefraction(Unknown Source) at org.sunflow.core.ShadingState.traceRefraction(Unknown Source) at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) at org.sunflow.core.LightServer.shadeHit(Unknown Source) at org.sunflow.core.LightServer.traceReflection(Unknown Source) at org.sunflow.core.ShadingState.traceReflection(Unknown Source) at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) at org.sunflow.core.LightServer.shadeHit(Unknown Source)The same render works fine when run on 32-bit JRE7. |
Current timezone is GMT Sep 27, 2026, 4:05:50 AM |
