Print at Sep 28, 2026, 2:31:18 AM
Posted by Larnorsh at Mar 21, 2013, 11:47:51 AM
Can't change the directory settings using -D option in SweetHome3D.l4j.ini file
I'm trying to use the option to change directory settings described at http://www.sweethome3d.com/javadoc/com/eteks/sweethome3d/SweetHome3D.html.
I have created a SweetHome3D.l4j.ini file stored in the same directory as SweetHome3D.exe with the parameters
-Dcom.eteks.sweethome3d.applicationFolders="C:\Egt\Etek\RunDir\Sweet Home 3D" and
-Dcom.eteks.sweethome3d.preferencesFolder="C:\Egt\Etek\RunDir\Sweet Home 3D".
But when I start SweetHome3D and open a project or load a furniture library it still use the "C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D" path and my roaming profile exceeds its limitation. I don't want to have anything stored under my roaming profile because I have to delete everything before i can log off my computer.
How shall I specify this option to get it work?
