Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Using Sweet Home 3D in Eclipse » » » » Post: Re: Using Sweet Home 3D in Eclipse |
Print at Sep 24, 2026, 6:19:49 PM |
| Posted by Puybaret at Mar 23, 2013, 8:21:11 AM |
Re: Using Sweet Home 3D in Eclipse I tried I'm pretty sure this command can't run, because the -jar option must be followed by a Jar file and the -D option must be cited before the -jar option. java -jar SweetHome3D -Djava.ext.dirs=lib:lib/linux/i386 By the way, the README.TXT file states that you should set the directory in the the -Djava.ext.dirs option according to your system and its architecture, i.e. for Windows 7 32 bit, it should be -Djava.ext.dirs=lib/windows/i386;lib and not -Djava.ext.dirs=lib:lib/linux/i386. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 6:19:49 PM |
