Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem Starting Online Version » » » » Post: Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font> |
Print at Sep 2, 2026, 5:20:34 PM |
| Posted by StNff at Mar 24, 2013, 11:50:59 AM |
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font> I had JDK 7. Now I have JDK 5 (As in the instructions). Log compilation: D:\1>ant javaWebStart Buildfile: D:\1\build.xml build: [mkdir] Created dir: D:\1\build\classes [javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 2 source files to D:\1\build\classes [javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 193 source files to D:\1\build\classes [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [copy] Copying 261 files to D:\1\build\classes [zip] Building zip: D:\1\build\SweetHome3D.jar [delete] Deleting directory D:\1\build\classes application: [zip] Building zip: D:\1\build\SweetHome3DStandalone.jar [move] Moving 1 file to D:\1\build furniture: [zip] Building zip: D:\1\build\Furniture.jar textures: [zip] Building zip: D:\1\build\Textures.jar help: [zip] Building zip: D:\1\build\Help.jar jogl-java3d: [zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar java3dLibraries: [mkdir] Created dir: D:\1\deploy\lib\windows\i386 [zip] Building zip: D:\1\deploy\lib\windows\i386\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\windows\x64 [zip] Building zip: D:\1\deploy\lib\windows\x64\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\linux\i386 [zip] Building zip: D:\1\deploy\lib\linux\i386\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\linux\x64 [zip] Building zip: D:\1\deploy\lib\linux\x64\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\macosx [zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar javaWebStart: [mkdir] Created dir: D:\1\build\JNLP-INF [copy] Copying 1 file to D:\1\build\JNLP-INF [zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar [zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar [copy] Copying 6 files to D:\1\deploy\lib [delete] Deleting directory D:\1\build [input] Enter Passphrase for keystore: 1111 [signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D [signjar] jarsigner error: java.lang.RuntimeException: keystore load: D:\1\keys.keytool (═х єфрхЄё эрщЄш єърчрээ√щ Їр щы) BUILD FAILED D:\1\build.xml:238: jarsigner returned: 1 Total time: 1 minute 40 seconds Tell me, what's the problem? |
Current timezone is GMT Sep 2, 2026, 5:20:34 PM |
