Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem Starting Online Version » » » » Post: Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font> |
Print at Sep 2, 2026, 6:45:21 PM |
| Posted by StNff at Mar 26, 2013, 4:43:28 PM |
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font> I had a warning: <b>build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds</b> So I decided to try Ant 1.7, building failed. I decided to try Ant 1.9 - building successful, but I still have the error ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet. I see no error in the log that generates this error. You may have a different opinion. I therefore complete log. <b>D:\1>ant javaWebStart Buildfile: build.xml build: [mkdir] Created dir: D:\1\build\classes [javac] Compiling 2 source files to D:\1\build\classes [javac] Compiling 193 source files to D:\1\build\classes [javac] Note: D:\1\src\com\eteks\sweethome3d\swing\JPEGImagesToVideo.java uses or overrides a deprecated API. [javac] Note: Recompile with -Xlint:deprecation for details. [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [copy] Copying 261 files to D:\1\build\classes [zip] Building zip: D:\1\build\SweetHome3D.jar [delete] Deleting directory D:\1\build\classes application: [zip] Building zip: D:\1\build\SweetHome3DStandalone.jar [move] Moving 1 file to D:\1\build furniture: [zip] Building zip: D:\1\build\Furniture.jar textures: [zip] Building zip: D:\1\build\Textures.jar help: [zip] Building zip: D:\1\build\Help.jar jogl-java3d: [zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar BUILD FAILED D:\1\build.xml:118: Problem creating zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar (╤шёЄхьх эх єфрхЄё эрщЄш єърчрээ √щ яєЄ№) (and the archive is probably corrupt but I could not delete it) Total time: 1 minute 13 seconds D:\1>ant javaWebStart Buildfile: D:\1\build.xml build: [mkdir] Created dir: D:\1\build\classes [javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 2 source files to D:\1\build\classes [javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 193 source files to D:\1\build\classes [javac] Note: D:\1\src\com\eteks\sweethome3d\swing\JPEGImagesToVideo.java uses or overrides a deprecated API. [javac] Note: Recompile with -Xlint:deprecation for details. [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [copy] Copying 261 files to D:\1\build\classes [zip] Building zip: D:\1\build\SweetHome3D.jar [delete] Deleting directory D:\1\build\classes application: [zip] Building zip: D:\1\build\SweetHome3DStandalone.jar [move] Moving 1 file to D:\1\build furniture: [zip] Building zip: D:\1\build\Furniture.jar textures: [zip] Building zip: D:\1\build\Textures.jar help: [zip] Building zip: D:\1\build\Help.jar jogl-java3d: [zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar java3dLibraries: [zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar javaWebStart: [mkdir] Created dir: D:\1\build\JNLP-INF [copy] Copying 1 file to D:\1\build\JNLP-INF [zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar [zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar [delete] Deleting directory D:\1\build [input] Enter Passphrase for keystore: 111111 [signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\SweetHome3D.jar to D:\1\deploy\lib\SweetHome3D.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar to D:\1\deploy\lib\SweetHome3DJavaWebStart Bootstrap.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\batik-svgpathparser-1.7.jar to D:\1\deploy\lib\batik-svgpathparser-1.7.jar as S weetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\freehep-vectorgraphics-svg-2.1.1.jar to D:\1\deploy\lib\freehep-vectorgraphics- svg-2.1.1.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\iText-2.1.7.jar to D:\1\deploy\lib\iText-2.1.7.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\jmf.jar to D:\1\deploy\lib\jmf.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\linux\i386\java3d.jar to D:\1\deploy\lib\linux\i386\java3d.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\linux\x64\java3d.jar to D:\1\deploy\lib\linux\x64\java3d.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\macosx\java3d.jar to D:\1\deploy\lib\macosx\java3d.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\sunflow-0.07.3g.jar to D:\1\deploy\lib\sunflow-0.07.3g.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\windows\i386\java3d.jar to D:\1\deploy\lib\windows\i386\java3d.jar as SweetHome 3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [signjar] Signing JAR: D:\1\deploy\lib\windows\x64\java3d.jar to D:\1\deploy\lib\windows\x64\java3d.jar as SweetHome3D [signjar] [signjar] Warning: [signjar] The signer certificate will expire within six months. [echo] deploy dir ready for ftp BUILD SUCCESSFUL Total time: 2 minutes 56 seconds</b> |
Current timezone is GMT Sep 2, 2026, 6:45:21 PM |
