Print at Sep 24, 2026, 11:05:41 AM
Posted by Puybaret at Apr 1, 2013, 10:40:14 AM
Re: Automatic dimemsion when you draw walls?
A tooltip shows the length the wall you currently draw, but this size is the distance between the start point and the end point of the wall in its middle. If this way of measuring walls doesn't satisfy your needs, you may also a room first then draw the walls around it by double-clicking in the room.
The dimensions can be drawn afterwards with the Dimensions creation tool.
