Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: rendering best-quality photos. » » » » Post: Re: rendering best-quality photos. |
Print at Oct 4, 2026, 6:23:05 AM |
| Posted by Puybaret at Apr 5, 2013, 12:09:07 PM |
Re: rendering best-quality photos. The .ini file is for the 32 bit installer version which comes with its private version of Java. Thus you don't need to install Java on your system, or if you installed Java, updating it won't change the Java version used by Sweet Home 3D. If you want to run Sweet Home 3D in 64 bit, you have to download the Jar executable version of Sweet Home 3D and install Java 64 bit (or use the one you already installed). Then, you can launch the command: path\to\java.exe -Xmx4096m -jar path\to\SweetHome3D-4.0.jarHope you can handle it... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 6:23:05 AM |
