Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problem with transparent texture » » » » Post: Re: Problem with transparent texture |
Print at Sep 2, 2026, 4:43:41 PM |
| Posted by Puybaret at Apr 6, 2013, 1:51:10 AM |
Re: Problem with transparent texture Strange issue that I didn't succeed to reproduce yet. Maybe you should apply your texture on a thin Box of the Miscellaneous category. You'll see that if you apply globally the texture on the box, or use the texture to replace the materials of its front or back faces (in version 4.0), you won't get exactly the same behavior. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 2, 2026, 4:43:41 PM |
