Print at Sep 29, 2026, 7:55:46 AM
Posted by kubu at Apr 22, 2013, 7:25:39 PM
Re: Java error on saving (or saving as) my file
Here it is:
Java Web Start 10.21.2.11 Uso della versione JRE 1.7.0_21-b11 Java HotSpot(TM) Client VM Directory home utente = C:\Documents and Settings\admin! ---------------------------------------------------- c: cancella finestra console f: finalizza oggetti nella coda di finalizzazione g: garbage collection h: visualizza questo messaggio della Guida m: stampa utilizzo memoria o: attiva registrazione eventi p: ricarica configurazione proxy q: nascondi console r: ricarica configurazione criteri s: esegui dump delle proprietà del sistema e della distribuzione t: esegui dump lista thread v: esegui dump stack thread 0-5: imposta livello di trace su <n> ---------------------------------------------------- Match: beginTraversal Match: digest selected JREDesc: JREDesc[version 1.5+, heap=-1-536870912, args=null, href=null, sel=false, null, null], JREInfo: JREInfo for index 0: platform is: 1.7 product is: 1.7.0_21 location is: http://java.sun.com/products/autodl/j2se path is: C:\Programmi\Java\jre7\bin\javaw.exe args is: native platform is: Windows, x86 [ x86, 32bit ] JavaFX runtime is: JavaFX 2.2.21 found at C:\Programmi\Java\jre7\ enabled is: true registered is: true system is: true Match: selecting maxHeap: 536870912 Match: ignoring InitHeap: -1 Match: digesting vmargs: null Match: digested vmargs: [JVMParameters: isSecure: true, args: ] Match: JVM args after accumulation: [JVMParameters: isSecure: true, args: ] Match: digest LaunchDesc: http://www.sweethome3d.com/SweetHome3D.jnlp Match: digest properties: [-Dcom.eteks.sweethome3d.deploymentInformation="Java Web Start", -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart, -Dcom.eteks.sweethome3d.lazyParts="SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D"] Match: JVM args: [JVMParameters: isSecure: false, args: "-Dcom.eteks.sweethome3d.deploymentInformation=\"Java Web Start\"" -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart "-Dcom.eteks.sweethome3d.lazyParts=\"SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D\""] Match: endTraversal .. Match: JVM args final: -Xmx512m "-Dcom.eteks.sweethome3d.deploymentInformation=\"Java Web Start\"" -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart "-Dcom.eteks.sweethome3d.lazyParts=\"SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D\"" Match: Running JREInfo Version match: 1.7.0.21 == 1.7.0.21 Match: Running JVM args match the secure subset: have:<"-Dcom.eteks.sweethome3d.deploymentInformation=\"Java Web Start\"" -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart "-Dcom.eteks.sweethome3d.lazyParts=\"SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D\"" -Xmx512m> satisfy want:<-Xmx512m "-Dcom.eteks.sweethome3d.deploymentInformation=\"Java Web Start\"" -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart "-Dcom.eteks.sweethome3d.lazyParts=\"SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D\""> Java 3D: implicit antialiasing enabled CacheEntry[http://www.sweethome3d.com/SweetHome3DUpdates.xml]: updateAvailable=true,lastModified=Thu Mar 21 23:23:16 CET 2013,length=59 com.eteks.sweethome3d.model.RecorderException: Can't save home C:\Documents and Settings\admin!\Desktop\Trapp1.sh3d at com.eteks.sweethome3d.io.HomeFileRecorder.writeHome(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$33.call(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$33.call(Unknown Source) at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source) at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.io.FileNotFoundException: C:\Documents and Settings\admin (Impossibile trovare il file specificato) at java.io.FileInputStream.open(Native Method) at java.io.FileInputStream.<init>(Unknown Source) at java.io.FileInputStream.<init>(Unknown Source) at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source) at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source) at java.net.URL.openStream(Unknown Source) at com.eteks.sweethome3d.io.DefaultHomeOutputStream.getZipUrlEntries(Unknown Source) at com.eteks.sweethome3d.io.DefaultHomeOutputStream.writeHomeZipEntries(Unknown Source) at com.eteks.sweethome3d.io.DefaultHomeOutputStream.writeHome(Unknown Source) ... 12 more
Thank you
