Print at Sep 29, 2026, 1:24:34 PM
Posted by Puybaret at May 7, 2013, 11:22:50 AM
Re: vertical diagonals
The workaround would be to use a box or a cylinder found in the miscellaneous category, resize it to make it look like a beam, export it with the 3D view > Export at OBJ format menu item, then import the export file with the Furniture > Import furniture menu item, and fine tune its orientation at the second step of the furniture import wizard using the Shift key + arrow buttons.
