Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: What happened to my 3D pane? » » » » Post: Re: What happened to my 3D pane? |
Print at Sep 29, 2026, 5:35:15 PM |
| Posted by Puybaret at May 10, 2013, 1:19:57 PM |
Re: What happened to my 3D pane? What system do you use? How did you install Sweet Home 3D? I noticed that under my Windows environment, the 3D view sometimes disappears after a window resizing when the program is run with Java 7 (that's the main reason why rhe installer version is still provided with Java 6). If it's your case, resize again the 3D view to make it appear again or use the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 5:35:15 PM |
