Print at Oct 2, 2026, 10:08:47 PM
Posted by Puybaret at May 29, 2013, 9:46:19 AM
Re: Where does SH save its .obj-list?
One tip though: the category of each object is stored in the preferences.xml file.
You could edit this file with any text editor, and change the text between > and < in the lines starting by <entry key="furnitureCategory#, like:
<entry key="furnitureCategory#4">Other</entry>
could become:
<entry key="furnitureCategory#4">My category</entry>
The problem is that it won't be easy to recognize each piece of furniture since they are identified by a number and not by their name (the name you gave to an imported object is defined in the entries with a key starting by furnitureName#).
Before doing any tests be sure to create a backup of your eTeks/SweetHome3D folder.
