Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: HQ rendering issue » » » » Post: Re: HQ rendering issue |
Print at Sep 30, 2026, 9:52:14 PM |
| Posted by Puybaret at May 30, 2013, 8:16:10 AM |
Re: HQ rendering issue Hans, I talked about the Linux script because I guessed you would like to try it too. But you're right, I didn't give enough details. Consider the each line starting by -D as a parameter you should add between exec "$PROGRAM_DIR"/jre1.6.0_43/bin/java and -Xmx... in SweetHome3D launch script, and separate each parameter by spaces (not line returns). Hope you can handle it. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 9:52:14 PM |
