Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Small black square "dots" on high quality renderings » » » » Post: Re: Small black square "dots" on high quality renderings |
Print at Sep 24, 2026, 4:33:21 PM |
| Posted by hal9000 at Jun 7, 2013, 9:06:41 AM |
Re: Small black square "dots" on high quality renderings - It's now possible to adjust many settings of SunFlow with some parameters given to the program. Rendering will be slower if you require a better quality, but it might help reducing the spots. The idea is that all the settings shown in the file PhotoRenderer.properties (used to set the default parameters of the renderer) can be changed by the user with System properties given at program launch (for example, under Windows, you could use the -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=3 in a SweetHome3D.l4j.ini file stored beside sweethome3d.exe, to improve the best rendering quality). Expect an article about this in the coming weeks. Hmmm... that help or not. In my case I saw the black squares for the first time when I changed antiAliasing.max to 3 while with the default value for the same scene they don't appear. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 24, 2026, 4:33:21 PM |
