Print at Oct 7, 2026, 10:38:37 AM
Posted by Puybaret at Jun 19, 2013, 11:50:19 AM
Re: Replacing one design with another
Can I replace the old window object once with a new widow object instead of manually inserting each new window?
Sorry, you can't.
If not possible from within the program, can I cheat by changing the object (window) in the sh3d file?
Yes if you keep the same name for it in the sh3d file, but it might not be easy to find the right file, according to the window you use. Be sure to create a backup, before changing anything in the sh3d file.
