Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Small printing issue with dimensions, but can work around with svg export » » » » Post: Small printing issue with dimensions, but can work around with svg export |
Print at Sep 2, 2026, 1:43:03 PM |
| Posted by SourAway at Jul 5, 2013, 11:50:11 AM |
Small printing issue with dimensions, but can work around with svg export Hello Forum, and thank you Emmanuel Puybaret for the great software you coded. I wanted to report a small issue when printing dimensions. The stop/end lines (don't know how to describe better) are a bit too thick in the print while they are displayed nicely in the plan. This applies also to the Print to PDF function. But the Plan SVG-Export worked wonderful with Inkscape. I just had to rescale/set the Objects pixel = cm and divide that by the scale for printing. So there's no hurry, I just wanted to mention it. Another proposal would be an option to limit the print area to the current selection. (This was greyed out in the windows print dialogue) |
Current timezone is GMT Sep 2, 2026, 1:43:03 PM |
