Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problem with File open » » » » Post: Re: Problem with File open |
Print at Sep 2, 2026, 1:43:13 PM |
| Posted by hal9000 at Jul 10, 2013, 7:50:27 PM |
Re: Problem with File open I just meant the filesystem permissions for your user or group. If you can open files on another folders, with a file explorer for example, then you have the permissions. May be Java has not the correct permissions then? As a workaround you can simply copy the file to your home folder, work on it and then, if needed, copy it back to the origin folder. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 2, 2026, 1:43:13 PM |
