Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Insulation » » » » Post: Re: Insulation |
Print at Oct 3, 2026, 4:59:15 PM |
| Posted by hansmex at Jul 12, 2013, 4:40:27 AM |
Re: Insulation Babsi, No, there's no simple way to do that. However, you could draw double (or triple) walls, using exact coordinates, then use Modify walls -> Pattern in plan to distinguish between the walls. Personally, I draw my cavity walls 30 cms thick, which is the standard in my country (10 cm outside wall, 10 cm cavity/insulation, 10 cm inside wall). Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 3, 2026, 4:59:15 PM |
