Print at Sep 29, 2026, 2:04:29 PM
Posted by hansmex at Jul 27, 2013, 11:00:16 AM
Re: Cavity wall isolation
SH3D doesn't have cavity walls.
You can (easily) make them yourself by drawing 3 parallel walls. I suggest using exact X,Y coordinates to avoid overlapping.
To insert walls and doors, use this trick:
1 - insert a (suitably thick) hatch or an invisible box by using CTRL + ARROW KEY. This will pierce your walls.
2 - using the same method, insert a door or window. This has the added advantage that you have more control over the placing and thickness of your door/window.
