Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create photo missing options? » » » » Post: Re: Create photo missing options? |
Print at Oct 3, 2026, 12:54:52 PM |
| Posted by hansmex at Aug 13, 2013, 4:23:55 PM |
Re: Create photo missing options? @hal9000 - Angelo The PhotoCreation plugin is obsolete. All its functions have been incorporated into SH3D at least since version 3.7. The plugin is NOT compatible with newer versions and will not work. @jdetmold - Jeff You need to provide more information if you want any hope of a solution. - What OS are you using? - What version of SH3D are you using? Which version number, installed or webstart? - Did you make any changes to your computer? Updates, or so? - Did you transfer the file from another computer? If so, areboth files the same? - Did you make changes to the file? Maybe add (faulty) models? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 3, 2026, 12:54:52 PM |
