Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Easy drawing mode » » » » Post: Re: Easy drawing mode |
Print at Sep 28, 2026, 5:17:53 AM |
| Posted by okh at Aug 22, 2013, 9:17:59 AM |
Re: Easy drawing mode Interesting point, my wish to fix this getting started issue would be: A "getting started plug-in" (a wizard, if you like), could be helpful in collating the key measures. A form asking: - Building footprint (?) (e.g. 600 x 1200 cm, inner/outer/centre wall) (up direction - degrees off North) (or co-ordinates of the corners) - Basement wall outside colour (foundation) - Outside wall default colour - Inside wall default colour Levels [ ] Terrain = elevation 0 [ ] Basement/foundatiion (elevation; height, outer wall thickness, floor thickness) [ ] Ground floor (elevation; height, outer wall thickness, offset from basement) [ ] First floor (height, floor thickness) [ ] Second floor (height, floor thickness) With these these co-ordinates entered, the wizared could generate the basic house outline, all ready for the interesting stuff and the house corner would be aligned exactly to co-ords 0,00/0,00 and measures would be accurate. Just a thought, and I really wish my digital skills extended beyond the basic form design so I could code it myself... :-( ok |
Current timezone is GMT Sep 28, 2026, 5:17:53 AM |
