Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I draw a Countertop by itself? Or a floating floor? » » » » Post: Re: Can I draw a Countertop by itself? Or a floating floor? |
Print at Sep 27, 2026, 9:48:45 PM |
| Posted by hansmex at Aug 22, 2013, 4:47:14 PM |
Re: Can I draw a Countertop by itself? Or a floating floor? Assuming you are using version 4.1, you can create a new level, and draw the floor/countertop on that level. The height of the level will be the thickness of your countertop. The elevation of that level will be the elevation of the countertop above the floor of the level beneath it. If drawing on a new level is a problem, draw the floor/countertop on the kitchen level, then use CTRL-X and CTRL-V to copy the room/countertop to the level above. Of course you could also use thin boxes with the correct elevation. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 27, 2026, 9:48:45 PM |
