Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Print detail of plans » » » » Post: Re: Print detail of plans |
Print at Sep 28, 2026, 2:37:46 PM |
| Posted by hal9000 at Aug 26, 2013, 10:32:22 AM |
Re: Print detail of plans For 1), although you cannot print only part of the plan, a workaround may be to export the plan to SVG format (right clicking on it) and then open the SVG file with some vectorial drawing application. I did a test with a small room inside a big room and opened the SVG with CorelDraw. I had to draw some squares to make clipping/intersections with the drawing in order to remove the undesired parts, since it's exported as a single object, but I finally kept the interior room only. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 28, 2026, 2:37:46 PM |
